throttle help
Old 10-16-2011, 07:35 PM
gatornation42's Avatar
Default throttle help
yes i have a 1987 f-150 4.9 straight 6, efi. sometimes when i am driving it the throttle will just surge up real hard. and sometimes darn near die on me. and others it will just run fine. i have replaced the throttle air control valve and it still does this. i have found a valcuum line that is all dry rotted but not sure if that would be causing the problem. i have been told to replace that and or the throttle position sensor. tight on money so wondering what will be my best bet.
Old 10-17-2011, 08:54 PM
no body has any help. i have 41 views and nobody has any ideas.
Old 10-18-2011, 08:47 AM
Bullitt94's Avatar
definately start with the vacuum line. Vacuum leaks can cause the vehicle to do funny things. I'd check all the lines in the throttle body and intake area while you are at it.
Garrett Kriegseis
06-12-2014 10:44 AM
russ3or8
06-15-2012 08:30 PM
WV-F150-4.2L
03-16-2011 06:34 PM
Rosemary Burt
10-05-2009 08:16 PM
thanos929
12-05-2007 11:15 AM
Quick Reply: throttle help
