wiper blades and washer fluid both went out
Next check would be the Wiper Control Module..
If your certain the #2 8.25A in the panel is good, then there should be power to the module.. Wiper Module controls the wiper and washer functions commanded by the multi function.
Key in ACC/RUN position, wipers set to HIGH,, check for voltages at the wiper motor connector,, Y/R and W wires. If none present, a quick test of at least the washer function/circuit at the multi function switch would prove out either the switch, or the module...
