'02 7.3 Stalling, not cps
Old 02-11-2008, 05:36 PM
GravityMike's Avatar
Default '02 7.3 Stalling, not cps
Truck has been periodically stalling and 'bucking' (if it weren't a diesel, I'd be chasing ignition problems!). This has been going on long enough that I've changed the oil twice. Oil filter, fuel filter, air filter all in good shape.
It's been to the dealer 3 times to no avail.They did replace the CPS, didn't fix the problem. It get engine code P0263 "Turbo boost sensor A circuit perfomance." This is a stock engine. Is it possible that the engine controller thinks the turbo is over pressured and is 'defueling' the engine - completely?
I'm at a loss, what do I do next? MAP sensor? Wastegate? What could cause this?
Thanks!
GravityMike
Old 02-11-2008, 10:24 PM
wass's Avatar
Default RE: '02 7.3 Stalling, not cps
My 6.0 has been doing that to the point of stalling, but I've been running non-winterized fuel in the rear tank and it's probably colder here. I switch to the front tank and it straightens right out. Don't know about the codes.
Old 04-23-2012, 07:29 PM
Taylor.f350's Avatar
See if you guys can help on this , I got a 94 f350 7.3idi with a turbo the guy I bought it from let it sit for the winter and the waste gate is stuck shut , I'm gonna pull it apart and break it free but my actuator diaphragm is broke so it won't open and close properly, would it be better for now to run it wide open so my turbo doesn't over boost
strahanimal
05-24-2013 07:26 AM
fishin250
04-27-2012 09:06 AM
holbrom
04-07-2011 04:49 PM
dano25
08-16-2008 11:25 PM
KJama
05-06-2005 06:09 AM
Quick Reply: '02 7.3 Stalling, not cps
