04 F350 won't start after EGR and Head gasket replacement!!!
I've had my truck for a while now and it was running fine until the EGR cooler went bad. I replaced it wit the delete kit and found out that the head gasket was blown. So I replaced the head gaskets as well and put everyting back the way it was. At this point the truck wouldn't start. It would turn over but not fire, so I checked the code and read cam + crank sensor codes. I replaced them both and the truck will still not start. I've checked the fuel lines and diesel is getting to the injectors. If I spray starter fluid into the intake the truck will run until I stop sprayin it then it shuts right back off. I'm at the end of my witts. Somebody pls help me!!!
ok this soounds like a prob i had with my 06 ford. my truck just died once, and it would crank and crank, but never fire. with it being under warranty i took it to ford. this was right after i had my egr coller replaced too! they told me it was because my oil pressure pump would only put out 300psi when it needed 500 to fire off. im not saying that this is your issue, but your symptoms mimic mine. so you might ask ford or a certifieddiesel tech about it! just relating my experience!
chillywilly454@aol.com
09-19-2010 11:59 AM
