no power to pcm relay
Old 11-28-2012, 10:08 AM
DaGovna's Avatar
Exclamation no power to pcm relay
Need some info. got a 1998 f250 with 7.3l
no power to key on side of the pcm relay at power dist. box
will not start and no com. with scanner followed the wire inside of cab
does anybody out there have a diagram for
this circuit or know were this wire comes from? I believe it should
be a 12 volt signal with key on any help would b
appreciated
Old 11-28-2012, 01:46 PM
Welcome to the site..
Fuse for the power relay is in the engine comparment box. #22-30 amp..
If the fuse is blown, or continues to burn, unplug the fuel heater, they like to take out the Power relay feed...
jozepy24
07-13-2019 05:21 AM
Jamesrumley
08-30-2014 11:12 AM
gruchol
07-05-2012 10:46 AM
Alanbw
09-14-2007 07:38 PM
pgh2160
08-19-2007 12:44 PM
Quick Reply: no power to pcm relay
