1998 ford f250 2wd
Old 03-20-2016, 08:47 PM
J5wilson7's Avatar
Default 1998 ford f250 2wd
Hello,
I have a ford f250 2wd 7lug 5.4 v8. My front spindle is hot can only keep hands on for a few seconds before it starts to burn. I have replaced the wheel bearings and I didn't over tighten them rotor spins freely. Replaced both front calipers and brake pads. Still hot. Is this normal for a 2wd? I know on a 4x4 that means the bearings are bad. Anybody have any ideas thanks for the help
Old 03-20-2016, 10:16 PM
A few questions,
How does the wheel that seems hot compare to the other front wheel?
When you replaced the calipers did you clean and lube the caliper pins?
Are you checking the wheels after some heavy braking?
If there is air trapped in the caliper, when it gets warm will expand and cause some brake drag.
Old 03-21-2016, 11:03 AM
J5wilson7's Avatar
A few questions,
It seems hotter the my passenger side. For the brake pads sliders I put bearing grease in where the pads slide. I also bleed all 4 wheels. I drove to my friends house check when I got out they were cold. Drove back from friends house and thenthe driver side was hot. Other then normal braking for traffic lights or cars that's was it.
Old 03-21-2016, 11:29 AM
J5wilson7's Avatar
A few questions,
Old 03-21-2016, 02:53 PM
The calipers bolt to 2 pins that allow the entire caliper to slide. Those are the pins I am referring to. They must be removed, pin surface cleaned and holes the pins go into must be cleaned out also,then lubricated with a synthetic grease that will not harm the rubber boots when installed. It does sound like one or both of the pins on the side that is getting hot are jammed full of rust, dirt ,etc. and may be difficult to slide. The caliper should have a little clearance at both top and bottom so it has room to move. Filing the rust off the spindle where the caliper slides also helps a lot.
cariboo4x4
07-05-2010 12:37 AM
bill9iron
12-02-2007 02:14 PM
rob17san
02-10-2006 01:39 AM
urlifewasoc
01-20-2006 08:32 PM
nicholsmf
10-29-2005 08:03 PM
Quick Reply: 1998 ford f250 2wd
