1999 F250 Gear Shift Lever Problem - Ford Forum - Enthusiast Forums for Ford Owners
Thread Tools Search this Thread
Old 07-06-2007, 10:52 AM
Default 1999 F250 Gear Shift Lever Problem
My gear shift handle/lever thing on my automaticis now extremely loose and will not go all the way over into park or 1st gear... I found a gold hex head bolt on the floor which I'm sure has something to do with it, but for the life of me I can't figure out where to put the dang thing back in! Anyone fix this before?
Old 07-06-2007, 12:04 PM
Default RE: 1999 F250 Gear Shift Lever Problem
Very common for the torx (2) screws to back out of the shifter arm at the base of the steering column/shift tube.. Look 'up' from the lower dash and you'll see the trans selector cable attached to the arm.. You'll then see the 2 torx screws (one in your case at the arm's base.. They 'should' be loctited and retightened, but can be just tightened.. Also somewhat common, is for the shifter tube bushings to fail and will cause the shifter tube to wobble some and be a little sloppy.. Not a hard job to replace, but requires the steering column to be lowered down (not removed) for access to the clamps torx screws.. Generally just the shifter arm tightening will make a huge improvement.. When your under the dash after tightening the shifter arm screws, move the shifter through the ranges and watch the shifter arm/selector tube to see if it moves 'up and down'.. Some movement is normal, but both of these conditions can/willmake for a 'shift hunt' range selection problem..
[IMG]local://upfiles/6756/45BBE5925E9F4A3C9AA9100A9005CCEF.gif[/IMG]
Old 07-06-2007, 12:44 PM
Do I need to remove the plastic cover from the steering column to access this? Or is is further back/down?
Old 07-06-2007, 01:19 PM
No...
If you look up from about where your feet would be on the carpet, look straight up and you'll see the main column body.. At it's base, or right about where the steering shaft enters the column body (follow on up from the firewall) you'll see a small ujoint at the columns base on the steerinfg shaft,, the shifter arm/tube is just above and to the passenger side of the steering shaft.. Tried to find you a better pic for clarity, but this will give you the general area looking from bottom up.. You'll need a #30 torx driver socket to pull it tight...
[IMG]local://upfiles/6756/02B7A91ABACB4CC8B051C807CA345632.gif[/IMG]
Old 05-15-2011, 05:39 PM
Thumbs up Thanks Hayapower
I couldn't start my F250 unless I put it in N and I knew it was a problem w/ the gear shift. Thank goodness for Ford fourum, it's all fixed now!!
Thread Thread Starter Forum Replies Last Post
Shift Lever Stuck gene52 Ford Thunderbird 5 04-04-2014 07:49 PM
Ford Falkon 1996r. - gear lever can not turn on the ignition jacek61 Fairlane/Falcon/Galaxie/Gran Torino 1 11-30-2013 02:54 AM
Can I install a new gear shift lever myself?? ironhide34 Ford Forum Help & Suggestion Center 0 05-16-2011 10:01 AM
Gear shift stuck in 2nd gear! Advice?! Yapalot Ford Expedition 1 04-26-2011 06:29 PM
Sloppy shift lever......big problem? swaman Ford Explorer 2 02-23-2009 08:26 AM
Tags
1999, colum, column, f250, ford, gearshift, hard, lever, localupfiles675602b7a91abacb4cc8b051c807ca345632gi f, move, problems, remove, shift, shifter, tube
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
