1999 F250 Rear end problem..! help
I have a 1999 F250 v10 4X4 had a major howl in it, so I took it apart and found out that the side bearing race was damaged pieces missing, so I replaced side bearings and races, as well the pinion bearings and races, and put it back together torqued it down to 30FLB and now it has a whine in the rear end, and is getting HOT! any suggestions would be great.
I think the pinion nut may be torqued down to tight...?
also it's a 10.5 ford rear end
thanks for the help in advance
Anytime the pinion bearings are replaced the 'crush sleeve' between the inner/outer pinion bearings 'must' be replaced and the new bearing preload set by tightening the pinion nut/crush down to spec bearing preload for a rotational drag in lbs/in..
Hondo Sackett
05-24-2010 08:05 PM
