engine bogs down when gas peddle is fully pressed. URGENT!!
Old 09-02-2011, 03:45 PM
BigRedFord's Avatar
Unhappy engine bogs down when gas peddle is fully pressed. URGENT!!
1978 ford f250 automatic. if i press the gas more than half way it wants to crap out. wont go up hills. had the alternator checked and it passed. oreilly autoparts said it was the regulator so i replaced it and it did nothing. please help!!!
Old 09-02-2011, 08:37 PM
Did you check for a good fuel delivery/volume to the carb, and the filter itself?. They had a small filter and easily plug..
Old 09-02-2011, 10:57 PM
BigRedFord's Avatar
I sprayed carb cleaner down it but it had no effect. Should I take the carb apart and clean it more thoroughly?
Old 09-03-2011, 08:00 AM
Gary2Wheels's Avatar
I had a MAP sensor go bad on my "94 F 250...showed the same symptoms.Have you checked the error codes?...your 'check engine' light has come on,correct?...
Old 09-03-2011, 08:12 AM
BigRedFord's Avatar
No its a 78 it doesn't have any of that
Old 09-03-2011, 09:10 AM
yep..well,I hasd a bad ignition coil do that once.It would idle,but then die when you tried to get more rpm....
Old 09-03-2011, 11:41 AM
Something you can check and won't cost anything except a few minutes of your time.
With the engine off and air cleaner removed , whether it's a 2 or 4 barrel carb, when you move the accelerator linkage to full throttle you should see fuel squirt out 2 jets every time you floor the pedal. If you don't see this you could have a poor functioning accelerator pump on the carburetor. Make sure the choke blade is open all the way so you can see down in the carb.
Let us know what you find, OK?
Old 09-03-2011, 04:56 PM
BigRedFord's Avatar
I checked and fuel comes out. It will even rev all the way if its in park or neutral just not in drive.
Old 09-03-2011, 06:44 PM
I would suspect an ignition problem.
As Gary previously stated ,a defective coil could cause this problem.
Are all the electrical connections from the battery on up in good shape?
Sometimes simple things,,,,,,,,,,,,,
When were the plugs changed last?
Old 09-03-2011, 10:03 PM
BigRedFord's Avatar
Il check the coil. The plugs were just replaced a couple months ago.
Quick Reply: engine bogs down when gas peddle is fully pressed. URGENT!!
