Location of TPS
Old Jan 26, 2009 | 08:56 AM
JBlk's Avatar
Default Location of TPS
I am receiving a code of low voltage at the TPS.I have looked in the area that it should be located but have failed to locate the sensor.The vehicle is a 93 F250 with a 5 L engine.Can anyone give me the location of the sensor?
Old Jan 28, 2009 | 08:41 PM
marks460's Avatar
hi, the tps sensor is hard to see and get at on your truck take off the air intake hoses from the throttle body and you will see a 3 wire sensor mounted upside down directly underneath and attached to the bottom of the throttle body(if memory serves me correctly the wire colors are green-black and orange)-that is the sensor you are looking for -the throttle body has to come off to replace the tps, replace the throttle body gasket also,mark.
Old Jan 29, 2009 | 08:45 AM
JBlk's Avatar
Smile TPS location
Mark 460, I thankyou for the information.I was begining to think that the TPS didn'texist on my engine.
ecreek
Feb 27, 2013 10:15 PM
RandSand
Sep 28, 2009 03:46 PM
dpfreddy
May 23, 2007 10:41 AM
justinrunge
Jan 2, 2007 11:04 PM
Davis
Apr 18, 2005 01:09 PM
