front brakes on an 02 F350 SD
Old 07-08-2008, 10:40 AM
Patrick's Avatar
Administrator
Default front brakes on an 02 F350 SD
So, im looking at putting new front brakes on one of my work trucks, and im wondering what im getting into...do i have to take apart the front wheel assembly to remove the rotors?
Old 07-09-2008, 02:30 PM
Default RE: front brakes on an 02 F350 SD
To answer your question more info is needed. Is it 4X4, 4X2, dual rear wheels, four wheel disc brakes?
Old 07-09-2008, 02:43 PM
Patrick's Avatar
Administrator
sorry..i should have included all of that..
its 4wd, 4 wheel disc brakes, dually diesel...
it is my understanding that the 2wd does require you to take apart the bearing assembly, but the 4wd does not. i got a dealer quote of 600 dollars for front pads and rotors...i can get the parts for under 200.
Old 07-09-2008, 03:30 PM
On your truck, just remove the wheel hub on the outside, eight nuts, and then the rotor should slide off, or if it's stuck you might have to persuade it.
Old 07-10-2008, 12:08 PM
Patrick's Avatar
Administrator
that was what i thought..thank you for confirming it!
Old 07-29-2008, 03:48 PM
Patrick's Avatar
Administrator
so, i pulled the front wheels, and it definately is not a slide off rotor...the condition wasnt bad enough for me to need to tear into it. however, i was told by you, and a handful of other people (and the parts store) that it should be a simple slide off although it isnt..any ideas on what my issue is here? perhaps im dealing with some odd trimline?
Old 07-31-2008, 12:33 AM
It is a slide off but duallys have an adaptor that bolts over the rotor. You need to remove the 8 nuts that hold the adaptor on and then the adaptor and rotor will come off.
whobub
10-15-2010 01:12 PM
troyhay
02-08-2010 08:45 AM
800revxs
09-23-2009 10:01 AM
rapz
12-28-2008 09:22 PM
Mike11C
07-24-2007 07:05 AM
Quick Reply: front brakes on an 02 F350 SD
