2006 6.0 diesel xl electrical or fuel system issue
Old 09-15-2016, 11:40 AM
Brian3150@gmail.com's Avatar
Default 2006 6.0 diesel xl electrical or fuel system issue
I currently have an issue with losing power to my instrument cluster intermittently. I've changed batteries. Sometimes after starting, idle is fine, but when I try to apply gas, i get the jerking feeling I'm about to run out of fuel, but I know I have about 1/2 tank. And at moment, power to dashboard is out. Instrument cluster, computer, fuel pump, injectors, FICM (again?), something else?
Old 09-19-2016, 11:49 AM
eric hoffmeyer's Avatar
Is the fuel tank filler cap vented correctly?
Old 09-19-2016, 11:57 AM
It's the original factory installed cap. Last week the problem finally threw 2 codes. 1) communication failure to instrument cluster. 2)low fuel sensor - and I had 3/8 - 1/2 tank at the time.
Possibility is the communication failure threw the low fuel code. I have appointment Wednesday
Old 09-19-2016, 02:17 PM
It is possible the instrument cluster has a problem, not uncommon.
Since the cluster is part of the network very likely resulting in communication failure.
Old 09-19-2016, 02:29 PM
That's what I read somewhere. My truck is a 2006. An article said instrument cluster problems were common from 2005-2007 in the 250's, 350's, trucks, vans and expeditions
Old 11-18-2016, 09:23 AM
Frank L. Chaput's Avatar
I sent my cluster off to Circuitboard Medics got it back installed it and I got the same issue as before. Runs fine then click all the gages peg and then nothing. Any ideas?
Old 11-18-2016, 12:07 PM
If possible, see if you can have the computer checked for any codes.
In the process of doing that , if the system will not or not allow the network to communicate there may be a problem in the instrument cluster or one of the other modules thereby blocking communication. Other than checking for loose /corroded connections a good scan tool will be required to get deeper into the system.
Are there any "add on" items on this vehicle?
willijimon
10-21-2018 08:07 PM
Brian3150@gmail.com
08-13-2016 10:07 PM
whateversclever
02-18-2011 10:12 AM
zaroslinski
07-13-2009 05:23 PM
grumpydave
01-18-2008 03:15 PM
Quick Reply: 2006 6.0 diesel xl electrical or fuel system issue
