Fuel separator tool
Old 12-02-2007, 07:37 PM
netwayne's Avatar
Default Fuel separator tool
Just had the dash indicator come on for water in the fuel. What tool and size is needed to open the drain in the fuel separator on a 2004 F-350 Turbo Diesel? Please note I am researching this for a friend.
Thanks!
Old 12-02-2007, 08:55 PM
Default RE: Fuel separator tool
6mm hex drive/allen..
Old 12-04-2007, 06:52 PM
netwayne's Avatar
Thanks!
Old 12-05-2007, 06:23 PM
The filter housing is located on the d/s frame rail
Old 01-05-2008, 01:28 AM
cmfd70's Avatar
My manual for my 2005 says there is a lever on the side of the separator but I crawled under there and it looks different then the picture in the owner's manual. Are we supposed to take that aluminum plug out that has the hex keyway in it? Why does my manual reference a lever to open the drain?
Old 01-05-2008, 01:11 PM
The round plug with the 6mm femal hex is the HFCM drain.. You can add the drain plug from a LCF truck that has not only a hex, but is knurled so to able to be drained without special tools or hand tightened.. It also has a 'T' anchor to help wick and stream the draining fuel away from the module and off of the frame rail..
[IMG]local://upfiles/6756/4104FD07B5A74BEEB973E96263BF7F2F.jpg[/IMG]
MJSTaurus
01-06-2014 08:05 PM
jmelees
04-03-2012 12:19 PM
HAWGJO
04-19-2007 07:48 AM
mk1rocco16v
02-20-2006 09:51 PM
simjack
09-27-2004 08:55 AM
Quick Reply: Fuel separator tool
