Ford Enthusiast Unofficial Resource
Go Back   Ford Forum - Enthusiast Forums for Ford Owners > Ford Trucks, Ford Vans & Ford SUV's > Ford F-250 & Ford F-350
Sign in using an external account
Register Forgot Password?
Search
Welcome to Ford Forum!
Welcome to Ford Forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
LinkBack Thread Tools Search this Thread
Old 09-28-2006, 08:13 PM
Default 2006 F-350 Wrench Light (Dash)
Today as I was driving and I noticed a light on the dash that came on, it looks like a wrench, but any way, I looked in the owners guide to see what that meant. It says something about the Electronic Throttle Control, and that the engine has defaulted to a "Limp Home" operation. Does anyone know what this means exactly. I only have 4300 miles on it.
__________________
If it ain't broke.........fix it til it is.
Old 09-28-2006, 11:58 PM
Default RE: 2006 F-350 Wrench Light (Dash)
You have a problem with the Accelerator Pedal Position (APP) Sensor...
The APP sensor is a 3-track potentiometer thats used to calculate 'driver' demands for fuel/throttle quantity. The sensor receives a VREF voltage from the PCM and provides a variable voltage signal directly proportional to the accelerator pedal position.
A detected malfunction of the APP sensor illuminates the electronic throttle control (wrench) indicator. A PCM detected fault on one of the 3 sensor signals permits normal engine operation. A fault with 2 sensor signals only allows the engine to operate at idle..
The throttle control is all 'fly by wire' meaning throttle control is done fully electronically... If you look just up above your accelerator peddle you'll see the Sensor/throttle control unit...
__________________
05 F250 C/C FX4 6.0
1969 Firebird Trans Am
2003 Hayabusa GSXR1300
Old 09-29-2006, 01:36 AM
Thanks for your reply, much appreciated, but does this usually mean a replacement? or is it possible that something came loose.
__________________
Old 09-29-2006, 01:54 AM
Probably just a defect part, could be a connector/circuit, but most just likely a needed replacement.. They failed occasionally even back on the 7.3's.. Not something new...
__________________
05 F250 C/C FX4 6.0
Old 09-29-2006, 02:01 AM
Thanks alot for your input, since it is still under warranty, it's off to the dealership.....................again.[sm=smiley19.gif]
__________________
Old 01-13-2011, 02:32 PM
my daughter is on the road now with this problem with the wrench and she says it has problems with power, anything she can do?
Tags
05, 2006, 60, dash, dashboard, display, f350, ford, freestar, freestyle, home, light, limp, message, wrench
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Our Sponsors
New Sponsors
© Internet Brands, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
SEO by vBSEO ©2010, Crawlability, Inc.
