2015 F-350 Driver Assist trailer settings...Pressure?
Old 09-12-2014, 05:14 PM
billc's Avatar
Default 2015 F-350 Driver Assist trailer settings...Pressure?
Hi.
Just bought a 2015 F-350 Super Duty Powerstroke with the factory tow package installed. Great truck!
But I have a question about one setting in the Driver Assist mode.
There are two features that I can activate: Backup assistance and some sort of pressure setting that has to do with trailer braking.
I'm offered three settings: Low, Medium, and High.
But there's nothing in the owners manual or anywhere else that I can find that states exactly what that means.
Does that refer to how much pressure I have to put on the truck brake pedal in order for the trailer brakes to engage? So, if the setting is on High, will I have to press on the brake pedal harder before the trailer brakes engage?
Or does that refer to how much pressure is applied to the trailer brakes when I step on the truck brake pedal? So there will be a the greatest possible pressure applied from the trailer brakes?
Anyone able to clarify that for me, please?
Thanks so much!
bc
Old 10-11-2014, 06:21 PM
azkingranch's Avatar
Billy
I suspect its related to how much pressure is placed on the break pedal, this is new feature wasn't on the 2011 I had, will have to experiment when i get enough miles on mine to tell one way or another.
Just picked up my new 2015 has less than a hundred miles.
Chuck
2015 F350 King Ranch White Platinum Met. FX4, LB, 3.55 elocker, man step, 2004 montana mountaineer 277rls
Old 01-24-2015, 09:58 PM
w6254m's Avatar
Originally Posted by azkingranch
Billy
Chuck
Same trying to get miles so I can figure it out too have 30 miles...
Old 01-26-2015, 11:46 AM
eric hoffmeyer's Avatar
I have a break controller on my 99 truck. You can manually set it to how much breaking activity occurs on the trailer. For example if the trailer is light one would use a minimum setting for break force to keep the trailer wheels from locking up. A heavier trailer should require a breaking force that is proportionately higher. The amount of foot pressure I apply to the truck break pedal does not change.
Hope this helps.
Eric
Old 01-27-2015, 12:15 PM
billc's Avatar
Default Solved the problem
Hope this helps.
Eric
Thanks, Eric (and others).
Turns out it was faulty wiring on the trailer. I finally hauled it into the dealer and had them scrutinize the circuit through the trailer and, sure enough, they found a short. Pretty sad for a brand new trailer. But the Ford was just fine, as I'd expected.
By the way, last week I traded my F-350 in on a new F-150. The suspension on the 350 was hammering my brain whenever I was on concrete (due to the slab seams). It was so bad that my daughter wouldn't ride in the truck with her baby for fear of shaken-baby syndrome. I didn't really need the extra grunt with the 350 and the 150 suits my needs perfectly so all is well on that front as well.
billc
09-02-2014 03:33 PM
Transit04
09-02-2013 05:04 PM
PhotoMaster
08-11-2008 09:23 PM
99EXP
01-16-2006 04:39 PM
Quick Reply: 2015 F-350 Driver Assist trailer settings...Pressure?
