2015 F-350 Driver Assist trailer settings...Pressure?
Hi.
Just bought a 2015 F-350 Super Duty Powerstroke with the factory tow package installed. Great truck!
But I have a question about one setting in the Driver Assist mode.
There are two features that I can activate: Backup assistance and some sort of pressure setting that has to do with trailer braking.
I'm offered three settings: Low, Medium, and High.
But there's nothing in the owners manual or anywhere else that I can find that states exactly what that means.
Does that refer to how much pressure I have to put on the truck brake pedal in order for the trailer brakes to engage? So, if the setting is on High, will I have to press on the brake pedal harder before the trailer brakes engage?
Or does that refer to how much pressure is applied to the trailer brakes when I step on the truck brake pedal? So there will be a the greatest possible pressure applied from the trailer brakes?
Anyone able to clarify that for me, please?
Thanks so much!
bc
Thanks so much!
bc
Billy
I suspect its related to how much pressure is placed on the break pedal, this is new feature wasn't on the 2011 I had, will have to experiment when i get enough miles on mine to tell one way or another.
Just picked up my new 2015 has less than a hundred miles.
Chuck
2015 F350 King Ranch White Platinum Met. FX4, LB, 3.55 elocker, man step, 2004 montana mountaineer 277rls
Chuck
Billy
Chuck
Chuck
I have a break controller on my 99 truck. You can manually set it to how much breaking activity occurs on the trailer. For example if the trailer is light one would use a minimum setting for break force to keep the trailer wheels from locking up. A heavier trailer should require a breaking force that is proportionately higher. The amount of foot pressure I apply to the truck break pedal does not change.
Hope this helps.
Eric
Hope this helps.
Eric
Solved the problem
Hope this helps.
Eric
Hope this helps.
Eric
Turns out it was faulty wiring on the trailer. I finally hauled it into the dealer and had them scrutinize the circuit through the trailer and, sure enough, they found a short. Pretty sad for a brand new trailer. But the Ford was just fine, as I'd expected.
By the way, last week I traded my F-350 in on a new F-150. The suspension on the 350 was hammering my brain whenever I was on concrete (due to the slab seams). It was so bad that my daughter wouldn't ride in the truck with her baby for fear of shaken-baby syndrome. I didn't really need the extra grunt with the 350 and the 150 suits my needs perfectly so all is well on that front as well.
Jordan Henion
11-16-2014 06:25 PM
Transit04
09-02-2013 05:04 PM
