6.9 idi HELP!!!
Old 08-28-2014, 01:07 AM
Mcree7258's Avatar
Default 6.9 idi HELP!!!
I'm having problems please help. I have a 85 f250 4x4 6.9 idi. I've pulled the engine and taken the engine apart to an extent. Here's where I'm having troubles, I cannot get the harmonic balancer off to save my life. I've tried a harmonic balancer puller and bent all the bolts in the process. (Threads in crank are still good) I've tried a slide hammer and had to stop because I didn't want to break the engine stand and or make the block fall out. Any help/advice would be greatly appreciated! Thanks in advance, Ryan
Old 08-28-2014, 12:34 PM
eric hoffmeyer's Avatar
Have you tried any penetrating oil like KROIL, or PB blaster> Hydraulic fluid is OK too.
Old 08-28-2014, 07:00 PM
As a last resort, you may sacrifice the pulley assy, but have you tried heat?
Old 08-30-2014, 12:53 AM
Mcree7258's Avatar
I will try all of that, block is covered in oil, grease, dirt from years of leaking, and previous owners doing nothing about it. I need to pull crank to bore block, worst case scenario would heat mess with crank or block by warping it?
Old 08-30-2014, 06:13 AM
Have used that method in the past. Just heated the pulley portion that is around the crank and not the crankshaft itself. It did take a combination of heat and a good puller to break it loose.
Rvasak
11-20-2014 02:30 AM
makuloco2000
02-09-2014 11:03 AM
makuloco2000
02-09-2014 10:33 AM
sectlandscaping
10-28-2012 12:47 AM
bunch-0-trucks
09-19-2011 10:25 AM
Quick Reply: 6.9 idi HELP!!!
