66 Ford 250 Clutch Linkage Rod
Old 07-13-2010, 03:42 PM
yodibodi's Avatar
Default 66 Ford 250 Clutch Linkage Rod
I broke my clutch linkage rod and can't find the part anywhere. Any suggestions? I am worried about a weld not holding? Should i just have a new one made? Help..thanks
Old 07-13-2010, 08:44 PM
If I remember correctly the rod has a 90 degree bend on one end and is threaded on the other end. Is this correct? If it is , a good piece of 3/8 stock rod will probably work. Any shop or garage with a tap & die set and torch should be able to make one for you. What do you think? hanky
ford98enth
03-12-2014 06:53 PM
barkfarm
02-01-2012 07:37 PM
Zeke6191
08-20-2011 12:09 PM
stang8895
01-11-2010 01:25 PM
eric souther
05-22-2005 12:13 PM
Quick Reply: 66 Ford 250 Clutch Linkage Rod
