Ford Enthusiast Unofficial Resource
Go Back   Ford Forum - Enthusiast Forums for Ford Owners > Ford Trucks, Ford Vans & Ford SUV's > Ford F-250 & Ford F-350
Sign in using an external account
Register Forgot Password?
Search
Welcome to Ford Forum!
Welcome to Ford Forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
LinkBack Thread Tools Search this Thread
Old 11-03-2006, 05:34 AM
Default 7.3 waste gate problem
My 99 F350 diesel has developed a problem when cold. It looses 90% of it's power and sounds like the exhaust is blocked off (just like a plugged up cat. converter). Once its warm it is fine. 4" exhaust turbo back and no restrictions. Thinking maybe the waste gate is messing up? Selinoid not opening for vacuum to travel to actuator? What tells this to open and close? Problem comes and goes while driving until its completly warm. Ideas?
__________________
06 F350 PSD I spent my money on Trucks, booze and
79 F250 466 NASCAR, the rest I wasted!
70 Gamagoat
62 Unimog wrecker
85 Ranger Rockcrawler/ 02 tube buggy-Rockcrawler
Old 11-03-2006, 02:24 PM
Default RE: 7.3 waste gate problem
Probably more the Exhaust Back Pressure Valve...
Its normal for the EBP regulator valve to close to aid in coolant/cab heating during low load, low speed engine conditions when ambient air temperature is below 45° and engine oil temperature is below 167°.. The EBP valve is PCM contolled and signaled with imputs from the EOT (engine oil temp sensor) IAT (intake air temp sensor) and in conjuction with exhaust back pressure sensor determine the Back Pressure Valve operation..
An open/shorted EBP sensor will disable the Back Pressure valves operation, but a out of range EOT, IAT 'might' signal a faulty imput.. Could be a sticking valve as well, but if it follows a regular pattern then it may not be a hanging/stuck valve .. If no DTC's/CEL are indicated, as a first step it should be scanned for codes, and matched PIDS (scanner data stream infomation/parameter info. display) for cold operation to varify normal sensors ranges or at least give an indication of whats it's not... Could be that the PCM is seeing a colder operating condition even when warmed, and is comanding the valve to close...
__________________
05 F250 C/C FX4 6.0
1969 Firebird Trans Am
2003 Hayabusa GSXR1300
Old 11-06-2006, 02:26 PM
Thanks for the info. Sounds right on the money. I'll have a friend scan it for me.
__________________
70 Gamagoat
62 Unimog wrecker
Old 12-10-2006, 03:50 PM
you can unplug your EBPV to see if that is the problem. there is a plug in front and a little to the right of the turbo. It is the only two wire plug. Try unpluging that and see if it fixes your problem. It will take a little longer for your truck to warm up with it unpluged, but your truck will run fine. I have had mine unpluged for quite awhile.
__________________
My Trucks,
1997 F250 ext cab 7.3, 5spd, one peice flywheel, 3" downpipe to 5" exaust to dual 6" bullhaulers, custom intake with K&N filter, Bully Dog 4pos chip, FPR mod, Autometer Gauges, Boost, Pyrometer, Oil Temp, 4"lift, Traction Bars, 35" tires, A
Tags
73, back, closing, exhaust, f350, ford, gate, photo, pressure, regulator, turbo, turbos, valve, waste, wastegate, wastegates
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Our Sponsors
New Sponsors
© Internet Brands, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
SEO by vBSEO ©2010, Crawlability, Inc.
