88 F 250 not chargeing - Ford Forum - Enthusiast Forums for Ford Owners
Thread Tools Search this Thread
Old 12-24-2011, 06:30 PM
Default 88 F 250 not chargeing
88 Ford not chargeing, Ault. checks ok tryed 2 different ones. Guage on dash just come in to the good area like it reads 10 volts. Battery reads 12 volts if I jumper from battery to the white wire Ault. will full field and maintain all the lights, heater, radio, etc. Need a wire diagram to figure it all out. Any idea where I might find one?
Old 12-24-2011, 06:54 PM
I believe there is a separate voltage regulator for your charging system. Look around on the R/S fender well for it .It may have a poor ground since they are mounted on the sheet metal and use that for its ground. Trying to locate a diagram, but in the meantime check the voltage reg and ground connection. If you solve the problem before we find a diagram , let us know.
Thread Thread Starter Forum Replies Last Post
1997 E-250 vs. 1999 E-250 brobichaud Ford Econoline E Series 0 07-20-2007 02:43 PM
03 F-250 4R100 not shifting to 3rd or OD MercuryMountaineer02 Transmission 1 05-27-2007 10:58 PM
1999 F-250 will not start Morris72 Ford F-250 & Ford F-350 1 03-14-2007 12:43 AM
11-97 F-250 NOT SHIFTING RAVEN LMS#12 Ford F-250 & Ford F-350 1 03-03-2007 09:19 PM
11-97 F-250 NOT SHIFTING. RAVEN LMS#12 General Tech 2 03-02-2007 12:13 AM
Tags
06, 88, 88f250, charging, diagram, diagrams, f250, f350, ford, problem, problems, regulator, system, troubleshhot, voltage, wiring
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
