Ford Enthusiast Unofficial Resource
Go Back   Ford Forum - Enthusiast Forums for Ford Owners > Ford Trucks, Ford Vans & Ford SUV's > Ford F-250 & Ford F-350
Sign in using an external account
Register Forgot Password?
Search
Welcome to Ford Forum!
Welcome to Ford Forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
LinkBack Thread Tools Search this Thread
Old 05-03-2006, 03:40 AM
Default 94 F250 5.8L, high idle and won't start problems
Greetings all. I'm looking for some trouble shooting suggestions. I search the forum but did not really find an answer. Here's the situation. Vehicle: 1994 Ford F250 with 5.8L, auto. I just purchased the truck at an auction a week ago so I don't know much history about the truck other than what I found under the bench seat (a lot of dirt and some french fries ;') Anyway, it was owned by a concrete/construction company and has been well used with 260,000+ miles shown on the odometer. I drove the truck home ~200 miles, every time I'd have to stop you could feel the engine fighting the brakes. In park or neutral the truck would idle rather high making for a good clunk when you would shift into drive or reverse. I asked a friend for some ideas and he told me to check the Idle Air Control Valve (IACV). Sure enough, if I unplug the connector to the IACV, the truck drops down to a nice low idle. If the engine is cold you might have to feather the gas pedal a little to keep it running, but when it warms up it seems to run fine with the IACV unplugged, (well, just sitting there in park, no A/C on or turning the wheel putting a load on the P/S pump.) I tried cleaning the IACV but it did not seem to make any difference. If I plug the IACV in, high idle. If I unplug the IACV, nice low idle. So I would assume that means that the IACV is junk, not just dirty, and I need to replace it.
QUESTIONS:
When the IACV fails, do they typically fail open or closed?
Can you take a measurment on the pins of the IACV to test if it is good or bad?
If you were to take a measurment at the wiring harness, what kind of a meter do you need? DMV or a Oscilliscope. What kind of reading should you be getting?
Second problem: Won't start without giving it a shot of starting fluid now. After I figured out that I could get the idle down by unplugging the IACV, I decided to degrease/clean the engine compartment. I sprayed a couple cans of GUNK Engine Cleaner under the hood, let it soak, then started it up and hosed it off. (NOTE: Did not need to use starting fluid any time before cleaning the engine.) I took the truck for a spin around the block to heat up the engine compartment and dry things out. During my spin I noticed that the truck was running like crap, I figured that there was some moisture in the distributor cap. I got home, opened the cap and confirmed my hunch. I blew the cap out with compressed air and strated the truck back up, (NOTE: No starter fluid needed.) I then proceeded to remove some of the misc. wiring that was left in the truck from the previous owners. I took my time doing this traceing the wires back to figure out the circuits. I removed the switch for a beacon light, another switch that went to some accessory that had already been removed, the power/antenna to what I assume was a two way radio, old car phone, and lastly a car alarm system. Again, I was very careful removing all the wiring, traceing the circuits making sure that I was not removeing any factory wiring. I then went to start the truck and it would crank but would not fire. I started to think that maybe something with the security system was preventing the engine from starting so I check for spark and confired that I had good spark. Then I thought maybe power to the fuel pump was being cut off so I sprayed a little starting fluid in the TB. I figured the truck would start and die as soon as the starting fluid was consumed, but to my surprise the truck keep running. I started to think that maybe the problem was due to the IACV being unplugged so I plugged it back it but it would still not start unless I gave it a shot of starting fluid.
QUESTION:
So why do I need to use starting fluid to get the truck started now? Once started it seems to run fine.
Point me in the right direction guys, PLEASE!!!
Chris
Old 09-13-2006, 03:58 AM
Send a message via AIM to malone
Default RE: 94 F250 5.8L, high idle and won't start problems
hi im new here today and i would like to help but this might be diffront from what you have going on.Ihad a 1988 ford ranger w/2.3 4 cyl and i had to eather it every time i started the thing after about 2 hours it would need it agien to start i drove it for about 1 year and alot of people looked at it and come to find out it was the brain in the truck and the only thing that gave it away was the smell of the gas if you start it in the garage the thing burned your eyes like pepper spray it was bad does yours smell bad?and mine did not run good on idol eather i bent the tab on the intake were the gas was to act like it was at a little foot speed inside and it ran good this was just my winter beater did not want to put the money into it so i hope this helps it might not this is not at all the same truck but same crap
__________________
f 250 5.8 4x4 auto w/od 190000miles gas was propane 1 ton springs plane jane no cruz,ac,tilt,smogg,and thats it has 9.5 ft myers plow
Old 09-13-2006, 04:09 AM
Problem was resolved by replacing the TPS. Thanks anyway.
Tags
250, 58, aerostar, engine, escort, f250, ford, high, iac, idle, idles, moisture, motor, mustang, start, stop, wont
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Our Sponsors
New Sponsors
© Internet Brands, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
SEO by vBSEO ©2010, Crawlability, Inc.
