no start
Old 04-06-2007, 12:18 AM
huntingsmoke74's Avatar
Default no start
hi all I am working on a 96 powerstroke and cant figure out what is going on. Ok I can start and drive this pickup when it warms up and has been running for a while you shut it off and it will not start back up. If you let it sit and cool for at least 2 hours it will start and run again but it will never die when it is running. I have checked the oil reservoir and it is full. What could be my problem
Old 04-06-2007, 01:03 AM
Default RE: no start
Sounds like a possible high oil pressure problem.. A leak/out of spec pressure can cause a no start 'hot' condition, then restart after cooling.. 500lbs needed for a start, and/or you can check for spec cranking pressure with a test gauge at the heads, or use a DVOM at the IPC or PCM.. DB/LG and GY/RD wires for a minimum of .83v during cranking.. PCM pins 87 and 91..
Old 05-03-2007, 10:34 AM
Some of the powerstrokes also had problems with the cam sensor. In some cases the cam sensor would cause a similar problem. Check for codesfirst, a cam sensor should set a code.
makuloco2000
10-22-2013 09:46 PM
mayor
11-18-2012 06:46 PM
NYCArmyWife
11-16-2008 12:29 PM
iownslaves
04-01-2008 06:03 PM
Ranger96
01-27-2007 06:18 PM
Quick Reply: no start
