96' Super Duty 7.3 clutch problems
Hi, I'm new to the forum & need some help. I have replaced my clutch master clyndr & bled the air. I still have to pump clutch pedal atleast 3 times before it won't grind when I try & put it in gear. If I blead it over & over I get the same results. I've heard that there is some type of change over in the flywheels,clutch,psi plate. Clutch does not slip ever. & I do get 1 bubble of air each time I blead, but only one. Thanks for any help you can offer.
You still need to bleed the slave cyl. See if that doesn't solve your problem.
FORDBOY99K
03-06-2006 02:53 PM
