ABS light on after changing batteries
Old 12-10-2012, 06:14 PM
MichaelC's Avatar
Default ABS light on after changing batteries
I have an 03 Ford F-350 6.0 that I was having trouble starting and I pulled out the batteries had them checked and put in 2 new ones after a week of sitting up. Now when I start it the yellow ABS light comes on. I tried getting the code on my Actron CP9175 scanner but no codes show up. Will ABS codes be picked up by a scanner such as this or are ABS codes stored differently? I tried disconnecting the negative cable on both batteries for several hours to see if this would clear the alarm but it has not. The ABS light was not on before I pulled out the batteries and no other work was done other than changing a couple of fuses for a brake controller I had installed. Any ideas how to clear this?
Old 12-11-2012, 02:16 PM
MichaelC's Avatar
Today I pulled the 2 fuses I changed but ABS light still on.
I removed the sensor on top of the rear axle checked ohms 1875 put it back - light still on
I started to bring it into town as a local parts store had an ABS scanner that would get me in the right direction and less than a mile down the road the light cleared. I don't have any idea why but I'm just glad it did.
vern
06-21-2019 11:41 AM
bluzzer
12-13-2018 08:56 AM
11Bravo
08-17-2015 12:32 AM
David DjKahuna Nunez
04-17-2012 07:43 PM
gkansa
02-08-2011 07:07 AM
Quick Reply: ABS light on after changing batteries
