Another~>No trailer brake lights/turn signals
Old 04-01-2010, 11:57 PM
TerraHauler's Avatar
Lightbulb Another~>No trailer brake lights/turn signals
2004 F350 Diesel factory tow package
No stop/turn on L or R, 7 pin or 4 pin, or in the wire connection located next to the frame rail. Hazrds do not work eith on trailer plug
Running lamps are good, as is my brake controler
Checked the rear ground on the drivers side frame rail, (must remove spare tire) and it was fine. When disconnected all the tail lights on the truck are dim, so it should be obvious if it was not making good contact.
Hmmm: when the rear ground was removed; the aux. lights, which are wired into the trailer "back up light" wire, turned on.
Fuse #6 is good
Front relays under hood:
Relays click normally, switched relays and still mormal sounding. They were pretty warm though
Test light probed the terminals with Left blinker on, Terminal 30 on relay has intermitant power with the blinker on, No power in any other relay terminals.
I do not get power from 12 volt battery charge on 7 pin
Running out of ideas
Thanks for the help,
Adam
Old 04-03-2010, 01:38 AM
Just checked the #30 terminal on the relay under the hood and i do not get constant hot with the ignition on or off.
Old 04-04-2010, 09:09 AM
Solved! The wire that go to the fuse panel under the dash came loose. Hooked up the connector and I was good to go. Funny thing was that I still had power to the fuse. Thanks for you help Rob
Old 04-30-2015, 05:18 PM
Steve Gregory's Avatar
I'm sorry but don't understand pin #30. I have running lights on 7 pin trailer plug, electric brakes but no l/r lights in trailer plug
stevprin
07-15-2019 08:33 AM
CADOP
01-01-2011 05:58 PM
stac
11-23-2010 06:09 PM
93f250xlt4x4
07-03-2008 10:02 AM
Arlo Baulzitch
11-18-2007 12:26 PM
Quick Reply: Another~>No trailer brake lights/turn signals
