Blinkers gone wild
Blinkers gone wild
Both blinkers come on whenever I turn on the left blinker, both blinkers also come on when I turn on the right blinker. The blinkers blink faster when I hit the brake? Any thoughts? Thanks, Mike
You have to excuse me , I'm not that sharp to figure out just what you mean by "blinker".
I gather you mean the signal lights, but do you mean the dash indicator or just the the outside lights front and rear or both plus the dash indicators? If you could be a little more specific it would help a lot, thanks.
Would help also if we knew if your vehicle had separate lights for rear signals or does it use the rear stoplite for a signal lamp also. Year and model would also be helpful.
So that anyone else and I can maybe be of any help and all of us be on the same page so to speak, brake lights are called "stop lights" and signal lights are usually called signal or blinkers.
Now hopefully , you can provide some addl info.
Just from what you have told us so far, It does sound like there is a poor ground connection for the lights at the rear. Can you check that out and see what you find?
whawkins
11-15-2005 07:08 PM
