2005 F-250 V8 Fuel Tank Filling Problem
Old 10-25-2007, 08:53 AM
ecx662's Avatar
Default 2005 F-250 V8 Fuel Tank Filling Problem
At work we have a 2005 F-250 extended cab long box 4x4 with the V8 in it. We are having issues with filling up the fuel tank. You put the nozzle in and it keeps clicking off. Why is this?? Is there a vent tube that is unhooked or something along those facts? They tell me it has been in the ford dealership a couple of times to be looked at and always comes back the same!
Any help would be greatly appreciated!
Thanks
Andrew
Old 10-25-2007, 09:08 AM
david paul's Avatar
Default RE: 2005 F-250 V8 Fuel Tank Filling Problem
i think its a common issue as i have a 87 f-350 crew and a 94 f-350 crew one is gas the other diesel and both have the same problem i just set the pump as slow as i can and just Wait patiently until they are full
Old 10-25-2007, 09:12 AM
ecx662's Avatar
It will even do it when the nozzle is set as slow as it can go. You will try to run it by hand and it clicks off as well!
Old 10-25-2007, 09:23 AM
david paul's Avatar
on mine there is a certain position i can place the nozzle that it will take it slow i know u can't put it all the way in i just keep moving it in and out till i get the right position I've also fount that it also helps to have the left side of vehicle uphill if possible
Old 10-25-2007, 11:49 AM
FordNutz's Avatar
If your fuel fill hose gets a kink in it , it will slow the escaping air from the tank, making the nozzle think its full. If it gets kinked badly this can cause your problem. I replaced the tank in my 95 andI had a kink in it. The fuel went in faster than the line would take it and it backs up and cuts off the pumps nozzle.
Old 10-25-2007, 01:11 PM
Was the TSB 07-15-4 performed/checked for slow fuel fill?
jlawson435
08-10-2014 01:07 PM
davidq
07-20-2009 05:12 PM
jrkosik
03-05-2009 06:52 AM
THEGOOSE
02-22-2009 10:45 PM
Quick Reply: 2005 F-250 V8 Fuel Tank Filling Problem
