Crankcase and HPOP Reservoir
I recently asked a question about an oil additive advertised to help clean up the spool valves and reduce sticking fo the valves.
I asked if the additive goes in the HPOP reservoir or the crankcase.
Answer was "The Stiction Eliminator is added to the crankcase. The crankcase oil circulates through HPOP reservoir also."
I thought the crankcase and the HPOP were separate.
Which is correct?
Thank you.
Eric
Which is correct?
Thank you.
Eric
Michael Leonard Woodcock
12-10-2012 08:36 PM
