Cutting out and worse mileage than ever
Old 02-20-2017, 10:03 PM
Fordman1993's Avatar
Default Cutting out and worse mileage than ever
I have a1992 Ford f-250 4x4 long bed regular cab with a 5.8L and a E4OD automatic transmission here in the last week I get only 9 mpg highway and it dies while reversing I did a oil change new cap rotor and wires and it still does it any ideas on what I should try next
Old 02-21-2017, 05:55 AM
On the driver's side of the fuel rail is a fuel pressure regulator with a vacuum hose connected to the top of it. Pull that hose off and see if any fuel comes out. If it does, the regulator assy must be replaced. It should be held in place by 3 allen head screws.
If the diaphram inside is ruptured fuel gets sucked into the intake causing an excessive fuel condition and poor mileage. Worth checking.
Old 02-23-2017, 09:34 PM
Thanks I know I smell gas in the exhaust so I will look at it in the morning and if so I'll get it replaced
hfb1957
01-08-2013 08:03 PM
FlFordGirl
04-30-2008 07:23 AM
suhksb
04-12-2008 06:48 PM
Sooner0233
04-02-2008 10:38 PM
bluecarpenter
07-15-2006 05:05 PM
Quick Reply: Cutting out and worse mileage than ever
