E 250 rear wheel stud replacement
Most of the time, axle removal is not necessary. If the stud is loose , you should be able to position the stud in a location to remove the stud without any special tools and install a replacement.
The replacement stud is drawn into position using a wheel nut turned backwards and the nut is tightened until the stud is fully seated.
