engine bogs down when gas peddle is fully pressed. URGENT!!
1978 ford f250 automatic. if i press the gas more than half way it wants to crap out. wont go up hills. had the alternator checked and it passed. oreilly autoparts said it was the regulator so i replaced it and it did nothing. please help!!!
Something you can check and won't cost anything except a few minutes of your time.
With the engine off and air cleaner removed , whether it's a 2 or 4 barrel carb, when you move the accelerator linkage to full throttle you should see fuel squirt out 2 jets every time you floor the pedal. If you don't see this you could have a poor functioning accelerator pump on the carburetor. Make sure the choke blade is open all the way so you can see down in the carb.
Let us know what you find, OK?
I would suspect an ignition problem.
As Gary previously stated ,a defective coil could cause this problem.
Are all the electrical connections from the battery on up in good shape?
Sometimes simple things,,,,,,,,,,,,,
When were the plugs changed last?
