engine oil leak
engine oil leak
I have a 2001 f250 with a 5.4 gas.I have an oil leak at the top of the engine at the rear of the motor. It appears to be a hose, and I am having troubles finding the leak.It is a pressure hose. When I run the engine it sprays, and worried it will catch on fire. Does any one have any experience?
thank you
thank you
maybe the pressure hose on the power steering pump has a hole ! i had that happen before, the pressure hose cracked at the crimp on the power steering hose and sprayed fluid all over the place ! is it motor oil and not power steering fluid ?
