Engine run on
Old 03-15-2014, 08:37 PM
neuma181's Avatar
Default Engine run on
I have a 75 f250 with a 390 and when i shut it off the engine will idle real low for about as long as it wants. I usually pull the choke and that kills it right away. i just set the timing and the idle is where it should be so if you all could help that would be great.
Old 03-16-2014, 08:39 AM
That goes back a bit, but some carburetors had an idle stop solenoid that as long as the key was on the solenoid held the throttle open to the correct adjusted idle speed then when the key was turned off the solenoid would retract and allow the throttle butterflys to close thereby dropping the idle speed so low the engine would shut down promptly.
They got the name of an anti-diesling solenoid.
Old 03-16-2014, 09:34 AM
Rusty Baker's Avatar
I know if the pistons had a lot of carbon on top, it would be hot enough to ignite the gas and you could get run-on for a few seconds.
Laura W
09-21-2010 08:33 PM
bonboy
12-10-2007 02:28 AM
winfield_blue_falcon
08-06-2005 01:10 PM
hicracer
01-31-2005 11:24 PM
Quick Reply: Engine run on
