F250 Air Conditioner problem
Old 03-31-2012, 08:54 PM
TMcLain's Avatar
Default F250 Air Conditioner problem
Does anyone have any other ideas? We have replaced the high and low pressure switches. Totally drained and recharged the system. What happens is the AC will blow cold for a while then it goes hot, then after a few minutes will go cold again, then hot. It is a vicious cycle. We had an AC guy look at it and the compressor is working and he doesn't have any other ideas. Do any of you guy have any other ideas?
Old 04-01-2012, 12:06 AM
Did you drain and recharge with a vacuum pump and pull a vacuum for at least 45 minutes then recharge? If not there is a good chance you have moisture in the system.
Old 04-01-2012, 11:33 AM
TMcLain's Avatar
Yes, that is what they did.
Old 04-01-2012, 11:39 AM
Does the compressor cycle at all any time? Does the magnetic clutch always stay engaged? Did they use a set of A/C system gauges ? What readings did they get when pulling the vacuum?
I hate to have to tell you this , but the A/C guy could have done better than that !!!
Old 08-12-2013, 05:38 PM
robomccarthy's Avatar
Default 2011 f250 PS AIR CONDITIONING ISSUE
AC on my 2011 f250 Powerstroke has gone bad. Blowing hot air. Dealer tells me it's a 'temp sensor' (60 dollar part) that needs to be replaced. 1,800 $ WORTH OF LABOR, as the dash needs to be removed. REALLY? Out of warranty, so now I drive a 60,000 dollar truck with the windows down. Anyone have any light they can shed on this? painful...
Old 08-13-2013, 02:38 AM
Like anything else, you might get a 2nd & 3rd opinion.
Old 08-10-2014, 03:23 PM
richiericchh's Avatar
My air conditioner is only coming out thru my defrost on my 2009, When I turn it on I hear a noise like a door has slammed, any body have any solutions or diagnosis how to fix this?
Old 10-20-2014, 10:04 AM
Lisacmac's Avatar
Default 2011 F250 start issue
I recently replaced an exhaust sensor (due to the truck shutting off while driving). Since I brought my truck home after the fix, it now turns over but does not start. 1 battery has been replaced per mechanic. Any suggestions on what the problem is? I feel purchasing this truck brand new was a huge mistake!
Old 10-22-2014, 11:33 AM
Slove1962's Avatar
Same problem. Any help?
Old 11-07-2014, 12:01 AM
John Renold's Avatar
Hey guys! In my Ford 250 the air conditioning will work fine most of the time but occasionally it loses it. If I floor it, it will come back. Do I need more freon? Hope anyone help me out.
Thanks in Advance
bart0537
07-01-2012 04:13 PM
shanes 04
07-16-2009 01:25 PM
ford4ever
09-04-2008 11:50 AM
paulntexas
05-08-2007 11:55 AM
renech
09-19-2006 11:36 PM
Quick Reply: F250 Air Conditioner problem
