F250 running bad
Old 08-23-2010, 09:45 PM
lugnut86's Avatar
Default F250 running bad
I have a 92 f250 4x4 5.8 It had been sitting four 2 years bought it had a tune up done new battery and brake lines and alternator it was running great. then out off no were running like crap, wont idle and sucking gas like crazy. so i put a MAP sensor in it and a fuel regulator both were bad still not running good, any help would be appreciated.
Old 08-24-2010, 05:37 PM
Frustrated 250's Avatar
Running bad..Very wide open field. What exactly is it doing? I have a 94 with a 5.8. Running bad with poor mileage could be anything from a bad idle air sensor, to a bad ignition wire or, the timing being off from a worn distributor. Just a backyard mechanic but will help if I can. If you can be more specific, I will do what I can to help.
Old 08-24-2010, 09:30 PM
lugnut86's Avatar
Default running bad
sorry for the lack of info, I was not using my head, the fuel regulator was bad so after I posted the message I checked the oil and it had almost a quart of gas in it. I changed the oil and plugs, and its running fine now. Sorry to waste everyone's time.
MrSauga
09-19-2012 04:26 PM
rlpatte
03-31-2012 08:45 PM
ycgoat
10-29-2008 06:49 PM
Mardav111
02-02-2007 04:37 AM
chippendale
04-01-2006 05:55 PM
Quick Reply: F250 running bad
