2003 7.3 diesel hard start
Old 03-06-2012, 12:47 PM
NedRidge's Avatar
Cool 2003 7.3 diesel hard start
I have a 7.3 with approx 223,000 miles on it.
I have replaced the glow plugs, fuel filter, air filter, glow plug relay, optima red top batteries (2)
When cold I always have to have the thing plugged in and after approx 7-8 hours of sitting outside it will try to run but chugs as though its not getting something.
Oil level is good and I plan to replace with T6. I will then do a top end oil replacement in the HPOP reservoir.
If I follow a sequence of turning the key on and waiting until all is done running then doing it again 2 more times it will start most of the time.
Any suggestions besides the dreaded injector replacement?
Old 03-06-2012, 12:59 PM
Were you able to check out the EOT sensor?
Old 03-07-2012, 08:44 AM
NedRidge's Avatar
Thumbs up Thanks Hanky
I have not checked the EOT sensor. In reading up on this it appears as though it could certainly affect the beast. Much appreciated
Old 03-07-2012, 09:21 AM
4x4fordoffroad's Avatar
Default hard start
quick test .unplug EOT sensor and start truck cold.if it starts and chugs its bad.
makuloco2000
10-22-2013 09:46 PM
DucksRUs
12-04-2010 12:08 AM
Gdaande
09-08-2008 12:28 PM
jkmf250
03-29-2007 05:16 PM
Ranger96
01-27-2007 06:18 PM
Quick Reply: 2003 7.3 diesel hard start
