Glow plugs, How hard are they to replace? - Ford Forum - Enthusiast Forums for Ford Owners
LinkBack Thread Tools Search this Thread
Old 12-26-2007, 07:41 PM
Default Glow plugs, How hard are they to replace?
How hard is it to replace glow plugs in a F250, 1996 power stroke 7.3L? Last time it was done dealer did it and only replaced 1.(done at 50K)I think I want to replace all of them. The old gal is getting harder to start even when plugged in. I assume the valve covers must come off. I see a power lead running down in the covers. I have some time off during the Christmas/New years. What kind of cost for the glow plugs? Thanks
Old 12-26-2007, 08:09 PM
Default RE: Glow plugs, How hard are they to replace?
First you may want to check to make sure the glow relay is functioning.. But, a more common problem on the earlier PSD's was burning at the valve cover (UVC) gasket connection/s (outer most wires/pins on each connector) andglows can drop off line if a connection is lost.. Look at the valve cover connections a see if you see evidence of high heat, melting/bulging at the connectors.. If they look OK, you can unplug the connectors and ohm test the individual glows and prove out circuit continuity through the outer cover connections for opens ect. without pulling the valve covers.. There's always a chance the stub harness are toast inside the covers too, or a failing or loose due to heatUVC connector/connection, and not actually a dead GP.. Not a terrible job to replace the GP's, but the UVC gaskets, and harness's can be a few bucks, more so in comparision to the cost of the GP's if burned on both sides..
Old 12-26-2007, 09:54 PM
what weight oil are you running? i was using the normal 15w 40 oil, but in winter i have to use the 10w 30, or the 5w 40 oil, all made by rotella, if i have the heavy stuff in it wont start if at or below ten degrees
Thread Thread Starter Forum Replies Last Post
Glow Plugs gatweet Ford F-250 & Ford F-350 2 12-09-2011 02:56 PM
1994-f350-glow plugs cat38548 Ford F-250 & Ford F-350 1 02-03-2007 10:13 PM
Glow Plugs..waiting to start Afkid75 Ford F-250 & Ford F-350 2 07-02-2006 01:52 AM
Remove & Replace Glow Plugs - Escourt 1.9 D (90-97) rayjolly Ford Escort 0 11-22-2005 04:02 PM
Glow Plugs???? sprdty21921 Ford F-250 & Ford F-350 0 03-11-2005 12:51 AM
Tags
0n, 1988, 1996power, bulging, check, cost, f250, ford, glow, plug, plugs, powerstroke, ranger, replace, replacing, stroke
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
