Head Gasket Replacement Good Idea or No?
Old 08-23-2010, 11:41 AM
chillywilly454@aol.com's Avatar
Default Head Gasket Replacement Good Idea or No?
I have a 2000 F-250 with a 5.4L Triton engine. I have been having ongoing problems with my truck overheating for about a month. After replacing the thermostat twice, the water pump, and radiator with having no luck with stopping it from overheating I am going to replace the head gasket. I do not have any obvious symptoms of a leaky head gasket (white smoke coming from the exhaust or anything) but I have been told by a mechanic that it is the head gasket that needs replacing. I am a bit leary to replace the head gasket because I have heard from a few sources (2 of which are mechanics) that after replacing your head gasket it is likely you will drop a bottom end. I do not see why replacing the head gasket would cause this to happen. Does anyone have any experience or knowledge with this?
Old 09-19-2010, 11:59 AM
steve01's Avatar
If you haven't tore your motor down yet, check your compression and see if 1 or 2 cylinders are low. If you have a low 1 make up a fitting to put compressed air into the cylinder that is low and see if you get bubbles in the radiator. This will save pulling both heads if that is the problem.
blackbeast
03-21-2008 12:32 AM
thanos929
07-19-2007 04:35 PM
mike0179
04-25-2007 06:25 AM
Mojave_Dread
08-17-2006 07:38 PM
Mojave_Dread
08-10-2006 03:26 AM
Quick Reply: Head Gasket Replacement Good Idea or No?
