How do i hook up a 2nd battery in my 78 f250?
A parallel connection would only need a ground cable added from the secondary battery to the chassis/engine, and a new positve cable run from the drivers side battery on over to the right side positive battery post, or, it could be connected to the battery side of the solenoid..
Hayapower is correct....but in my opinion it is much better to also isolate the batteries from each other with an aftermarket voltage regulator. This is placed where the positive cable from second battery would connect to positive side of primary battery.
check http://www.vandwellers.org/isolator/index.html for a great diagram and more info...
It would be worth the 20-30 dollars to purchase an aftermarket voltage regulator to isolate the second battery from the first....then run a deep cycle battery as the secondary power source....and hook up aftermarket items directly to deep cycle (amp and stereo...etc)
Main reason is that this setup will keep primary battery fully charged for essential uses(starting engine...etc) and secondary battery can be run down significantly and still be recharged..
if you hook them up directly in parrallel without regulator...you can run them both down simultaneously and be stuck with two dead batteries...but you can listen twice as long as you do now!!
also consider an aftermarket alternator with higher output if you are running more than the normal amount of accessories.....
That was the reason I asked if it was going to be an AUX battery.. If he needed just some extra reserve, then possibly just a parallel connect.. A heavier draw w/KOEO, or the possibilty of a component being left on, or for long periods of time the system should be protected with a battery issolation switch..
Fordtough95
04-26-2012 03:32 AM
mjenson2007
05-31-2007 07:11 PM
