How to replace steering box 2000 f-250
RE: How to replace steering box 2000 f-250
Not bad to do..
You'llneed a puller to get the pitman arm off.. An 1 5/16 socket for the shaft nut.. Usually you can get the P/S lines through the wheel opening with just basic metric wrenches, or crows feet topside if you got'm.. Make SURE the steeing is locked, or the steering wheel is secured before removing the input yoke bolt.. You don't want the steering wheel turned causing the the airbag clock spring to go out of rotational count....
[IMG]local://upfiles/6756/B84FF898AAE148F79260DBD5C614EC16.jpg[/IMG]
JustMeee
09-17-2015 11:03 AM
jg333
02-11-2007 02:18 PM
