My radio will not turn off HELP!!! - Ford Forum - Enthusiast Forums for Ford Owners
Thread Tools Search this Thread
Old 07-20-2010, 10:37 PM
Default My radio will not turn off HELP!!!
I have a 2007 F 350 King Ranch dually. When I shut the truck down the radio continues to play like it is suppose to. The problem is when I remove the key and open the drivers door it continues to play. I can open the passenger door and it goes off. Could this be a problem with the drivers door switch? If so where is it located and how do I get to it. If not does anyone have any other ideas? Thanks!
Old 07-21-2010, 12:28 AM
Welcome to the site..
Door ajar switch is mounted upside down in the door latch.. They like to 'hang' or stick from debris collecting on the pin.. Sometimes spraying the door latch with some silcone or graphite based lube in that latch area and then repeatedly opening/closing the door will get it to function..
If you open the drivers door, does the interior/dome lights come on? Any 'door ajar' indication on the IP panel?
If none, you could always remove the door panel (very easy task) peel back the moisture guard (towards the back/latch) and reach in and unplug the switch as a test..
Thread Thread Starter Forum Replies Last Post
2003 Escape - turn signals, radio, power windows, interior illumination not working samchristine Ford Escape 1 04-05-2015 05:09 PM
95 tbird ignition problem. can turn on and wont turn off, hadda pull the battery xxtank88xx General Tech 2 11-28-2011 02:13 PM
Power Button won't turn off radio Steveromo Audio / Visual Electronics 0 05-05-2011 07:14 PM
Radio does not turn off when door opens TexasUltra Ford Excursion 0 05-04-2009 10:55 AM
radio doesn't turn off when pushing in button anoll62 Ford Explorer 1 03-18-2009 02:04 PM
Tags
2003, 2006, 2007, accessories, door, expedition, f250, f350, focus, ford, key, radio, shut, turn, wont
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
