Need Help with tail light
Hello,
I own a 2008 F250 and just the other day my right rear turn signal decided to fizz out on me. I've been looking all over the internet for a tutorial or just some advice on where the location of the right rear bulb would be. If anyone can please reply it would be greatly appreciated.
Thanks
Thanks
Open the tailgate and look inside the jamb where the tailgate support cables attach.. You'll see '2' bolts about 5/16 in size.. Take both out, and on the outter body side there are '2' hidden upper/lower 'bullet' style retainers that snap the lens assembly into place on the body panel.. 'CAREFULLY' (after the bolts are removed) but with moderate force, 'pull' the lens assembly backwards 'evenly' to get the retainers to 'unsnap'.. They hold fairly tight but can easily be removed by grabbing the assembly with your hands and pulling it backwards and 'slightly' outward.. The lamps sockets are 'twist' to release..
