No Crank/Start in Park
Old 11-17-2013, 04:59 PM
makuloco2000's Avatar
Default No Crank/Start in Park
Forgot about this common issue with the Superduty and Excursion vehicle that while it won't leave you stranded, it is a pain to live with. It has to do with the shift linkage bracket bolts coming loose and losing the shift cable adjustment as a result. Check out the video, as you will likely run across this at some point in your ownership of the Superduty. I hope my video helps!
jlhalz
01-31-2021 09:41 AM
makuloco2000
11-25-2013 08:38 PM
maxpower
06-24-2013 08:58 PM
ladyferricher
05-06-2004 01:44 PM
Quick Reply: No Crank/Start in Park
