No Start: High Pressure Oil Pump & Fitting Removal
Old 03-23-2014, 06:39 PM
makuloco2000's Avatar
Default No Start: High Pressure Oil Pump & Fitting Removal
Ok so this is a real common issue and the latest design high pressure fitting is a permanent fix from Ford. This issue of blown apart STC fittings started with the redesign in 2004.25. I really thought all of them were replaced by now with one of the two redesigns Ford came up with, I was wrong! Here we have a 2005 F250 no start due to this fitting coming apart so bad it cracked the rear cover. I know if I owned a 6.0L this would be on the top of my to do list for sure BEFORE it fails so I don't get stranded. What is worse is a cracked rear cover is $400 alone not to mention labor. Call this preventative maintenance and here is how to do it in your driveway!
Old 04-18-2014, 01:50 PM
lovemyford's Avatar
This was a helpful post. thank you
makuloco2000
08-31-2014 05:25 PM
tony tiger 54
04-30-2011 02:53 PM
daveranger
07-23-2008 07:32 PM
joel.garcia
10-22-2007 01:04 PM
mark shaw
01-22-2006 02:14 PM
Quick Reply: No Start: High Pressure Oil Pump & Fitting Removal
