1984 F250: on the frame in front of the saddle tanks
Old Jan 13, 2010 | 06:40 PM
1984F250Man's Avatar
Default 1984 F250: on the frame in front of the saddle tanks
(inside of the frame, drivers side) is either a fuel tank switch or an electric fuel pump. It has fuel lines running to it and connecting to one going up front. It has one wire going to the base of it.
Can anyone tell me which it is?
Secondly, if it is a fuel tank switch and I have removed the front tank, is there any reason I cannot route around that switch and directly to the fuel line going to the carb? (as long as I leave the flip switch set on the rear tank when I route around it)
Old Jan 26, 2010 | 09:09 AM
jackbudahbelly's Avatar
yep thats your fuel tank selecter. , I would loop a line to the empty ports just incase it starts to leak ,,,,, better yet just bypass valve an run hoses direct to fuel pump
jrose
Jun 27, 2021 03:18 PM
Scav
Jan 28, 2020 01:06 PM
indigoshaman
Feb 22, 2012 04:22 PM
mjohnston4314
Jun 29, 2007 10:30 AM
JimP
Mar 8, 2005 03:30 AM
