How do i hook up a 2nd battery in my 78 f250?
Old Jan 21, 2010 | 12:19 AM
BigRedFord's Avatar
Question How do i hook up a 2nd battery in my 78 f250?
I have a 78 ford f250 and it has a place for a second battery and i was wondering if someone could tell me how to hook one up.
Old Jan 21, 2010 | 12:45 AM
Are you looking to hook it up as an AUX battery for a camper/trailer, or in parallel as a second battery for the starting/truck system?
Old Jan 21, 2010 | 12:57 AM
BigRedFord's Avatar
parallel, i have an amp and the battery dies pretty fast when the trucks off and im listening to music.
Old Jan 21, 2010 | 01:29 PM
A parallel connection would only need a ground cable added from the secondary battery to the chassis/engine, and a new positve cable run from the drivers side battery on over to the right side positive battery post, or, it could be connected to the battery side of the solenoid..
Old Jan 21, 2010 | 03:52 PM
digital_diversion's Avatar
Hayapower is correct....but in my opinion it is much better to also isolate the batteries from each other with an aftermarket voltage regulator. This is placed where the positive cable from second battery would connect to positive side of primary battery.
check http://www.vandwellers.org/isolator/index.html for a great diagram and more info...
It would be worth the 20-30 dollars to purchase an aftermarket voltage regulator to isolate the second battery from the first....then run a deep cycle battery as the secondary power source....and hook up aftermarket items directly to deep cycle (amp and stereo...etc)
Main reason is that this setup will keep primary battery fully charged for essential uses(starting engine...etc) and secondary battery can be run down significantly and still be recharged..
if you hook them up directly in parrallel without regulator...you can run them both down simultaneously and be stuck with two dead batteries...but you can listen twice as long as you do now!!
also consider an aftermarket alternator with higher output if you are running more than the normal amount of accessories.....
Old Jan 21, 2010 | 04:25 PM
aftermarket voltage regulator is also called a Battery Isolating switch. (An automatic cut off solenoid type.)
Old Jan 21, 2010 | 06:43 PM
That was the reason I asked if it was going to be an AUX battery.. If he needed just some extra reserve, then possibly just a parallel connect.. A heavier draw w/KOEO, or the possibilty of a component being left on, or for long periods of time the system should be protected with a battery issolation switch..
Old Jan 21, 2010 | 07:16 PM
BigRedFord's Avatar
Thanks guys your a big help! sick of jumpin my truck
Fordtough95
Apr 26, 2012 03:32 AM
Iescaped
Jan 24, 2009 09:07 AM
POLiSH
Jun 15, 2007 01:04 AM
mjenson2007
May 31, 2007 07:11 PM
strider380
Mar 15, 2007 01:28 AM
