Putting A/C in a non A/C truck
Has anyone added air to a truck that did not have factory air. I want to put air in my truck and it does not have it, I found a complete kit for $1100 but that is a little expensive. I was thinking about getting some used parts from the junkyard and putting a system together. Any thoughts???
New to me AC
I'm looking at the same exact dilema. I have delt with this before. The important thing is that you research what years and models had the same AC equipment as your year/model. Make sure you get the entire system out of the donor car, ie. controls, compressor, hoses, condensor and (just looking at my upcoming job I think I will need the atmosphere control box). Take the time to do your due-dilligence and you will not be disappointed, leave out a couple parts and you will have headaches. The factory AC unit should bolt in on top of the engine where the idle pully mounts.
Best of luck!
Best of luck!
WildChild
02-03-2005 01:08 PM
