Ford Enthusiast Unofficial Resource
Go Back   Ford Forum - Enthusiast Forums for Ford Owners > Ford Trucks, Ford Vans & Ford SUV's > Ford F-250 & Ford F-350
Sign in using an external account
Register Forgot Password?
Search
Welcome to Ford Forum!
Welcome to Ford Forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
LinkBack Thread Tools Search this Thread
Old 12-18-2008, 12:42 PM
Default Replacing Clutch Slave Cylinder
Folks, kindly advise how to change the clutch slave cylinder on my 1988 F250 pick up. I notice that the pipe end is not threaded. Secondly, what is the procedure for bleeding the brakes and the clutch hydraulic?
Thanks.
Old 01-08-2009, 09:53 AM
Default RE: Replacing Clutch Slave Cylinder
hi, you must use a thin punch to remove the small roll pin that attaches the slave cylinder to the fluid line -the new cylinder will come with a new oring and roll pin-fill the master cylinder resivoir and gravity bleed the the slave cylinder(small allen screw on top)pump ALOT to bleed all the air from the system keep checking to make sure the master cylinder does not run out of fluid
Tags
1988, 250, 88, bleed, clutch, cylinder, econoline, f250, f350, ford, located, remove, replace, replacing, slave
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Our Sponsors
New Sponsors
© Internet Brands, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
SEO by vBSEO ©2010, Crawlability, Inc.
