Shocks
Old 08-24-2016, 09:56 PM
eZAK's Avatar
Question Bilstein shocks
So I'm putting on a set (4) of Bilstein shocks on my 2011 F350.
Rears went great! Torq'd to repair manual specs.
Front no so! Had a heck of a time getting the top nut off.
I had to take off the inner wheel well and break out the air ratchet.
Installed the new Bilstein. Went to torq down the top nut.
Repair manual says 46lb-ft But I can only get about 20lbs
before the rubber bushing start looking like an "O" ring about 3/8" thick.
Should I continue to crank down until I get to 46lbs or what ??????
Thank You!
Old 08-24-2016, 10:38 PM
Welcome to the site..
Make sure the suspension isn't hanging on the shocks top bushing when tightening. If the truck is lifted for/ during the replacement, it can drop the suspension and make starting the top nut difficult, and put extra stress on the top bushing during tightening...
Old 08-25-2016, 09:44 AM
eZAK's Avatar
The front shock installed easy.
My concern is with the top nut torque specs.
As stated above, I'm not even close to 46lb-ft and it is flattening out the top bushings.
Old 08-25-2016, 09:53 AM
Not sure on the shocks torque, but if both halves of the bushing are equal in the amount they flatten (?), I'd tighten the stem nut down enough to make them bulge out slightly beyond the bushing washer/retainers OD. Squashing or over flattening them out, will most likely cause them to split.
Old 08-25-2016, 09:56 AM
eZAK's Avatar
OK, Thanks!
EFfalconsrule
04-10-2013 05:26 AM
blakeoe
04-01-2006 08:17 PM
bc in da hzhouse
12-05-2005 01:58 PM
rrubalc
12-05-2005 02:21 AM
PartsHookUp
11-29-2005 08:22 PM
Quick Reply: Shocks
