Speedometer/tach problems F350 6.0
Old 02-06-2007, 04:32 AM
Beater's Avatar
Default Speedometer/tach problems F350 6.0
Just bought a new 06/f350 6.0l. 500 hundred miles on it now and the tach and speedometer don't work sometimes. Coming to work tonight tachs on 500 rpm and speedo is on 95mph. I'm going around 70mph I figure. This is the second night it has happened.. Truck shutoff is now reading 15mph. I tried turning the truck off and re-starting it but it didn't change. It appears to drop back to 0 mph after stitting for a few hours then works correctly for a while until I stop a light then will be erratic after that. Same for the tach. I don't see any TSB listed for it. Any ideas?
It is also around 0 degrees here.
Nate
Old 02-06-2007, 03:03 PM
Default RE: Speedometer/tach problems F350 6.0
Here's the TSB for your concern....
[IMG]local://upfiles/6756/50C0B19B6DD24FBA94454F9ED6B80F69.jpg[/IMG]
[IMG]local://upfiles/6756/73FE31D1AA044637AB60249D11489568.jpg[/IMG]
Old 02-07-2007, 03:57 AM
Beater's Avatar
Thanks for the info. Don't know why I didn't see that TSB. Everything worked fine coming to work tonight. I'll have to find time to drop it off at the dealer.
rudelac
03-02-2013 06:45 AM
eloycastro22
09-03-2012 11:48 PM
millhouse0323
02-09-2008 10:43 PM
lmthibad
08-09-2006 01:23 AM
Quick Reply: Speedometer/tach problems F350 6.0
